Masking for sharpening
Two issues here. Firstly there is no option to invert a mask which because the “Subject” masking option is wholly inadequate means I have to manually do the masking which is time consuming. What would help is to be able to select the background and then invert the selection or alternatively have an option to select everything except the background. Point 2 is that having laboriously completed the mask and I want to save it as a preset I get the message " We have modified your selection so the preset can be used across multiple images. That means I have to. manually make a mask selection on every nearly identical image. This is a pain.
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
I have sent you a MOV file. Please note that this error only occurs on the first iteration so I don’t think the original files will help you as there is a SABU going on somewhere. I use an iMac with OS Big Sur version 11.7.10. Please ask if you need more information.
Nicholas Reuss
nicholasreuss@icloud.com
+66 (0)83 116 2156
