Does anyone know if there is a way to import a mask created in Topaz Mask AI into a mask in Topaz Studio 2? Thanks! Is there a tutorial that demonstrates this?
Thank you.
There is no way at this point in time.
That feature is being worked on and should be getting ready to hit beta soon.
Greetings again,
I see that there is now an integration of Mask AI with Topaz Studio 2. You’ll note from the emails below that this has been of interest to me since Mask AI first came out. Unfortunately, I used up my 30 day trial back in January when I was researching this issue. Since I cannot test the integration with Topaz Studio 2 now, could you tell me if there is new documentation or even a tutorial that explains the process?
Many thanks.
-jim noel
There is no separate documentation, Mask AI appears in the Plugin menu and is simply called and the mask returned to Studio 2.
