I hope you got this fixed. I did a fresh reinstall of Windows and installed Version 1.3.7. The program would crash when I choose detect subject or sky. I downloaded version 1.3.6 from Mask AI - Topaz Discussion Forum and installed that. It worked first try. Then just for the sake of troubleshooting, I used the full install of Version 1.3.7 install and it continued to work. Not sure what actually fixed it, but don’t want to break it trying to find out. Hope that helps you.
If you read above it tells you the workaround to get it to work.
Thank you all for your patience on the crashing issue with auto-detect Subject or Sky. We’re working on a fix and hope to get it out soon.
Meanwhile, @AiDon thank you for pointing people to the workaround!
Thank you. You have called a spade a spade, it is an issue which requires a fix.
Is batch processing (and Photoshop Action batch support) going to be added? I hope so, it’d be a gret leap for this program…
