Mask AI v1.3.5
October 14, 2020
Online Installers: mac | win
Full Installers: mac | win
New Features:
  • edge shift slider to use pixels instead of percentages
  • color range tool permits painting red on green, or green on red
  • improved caching of models
Fixes
  • fix fill tool not triggering auto-update mask
  • reduce artifacting when foreground recovery and edge shifting are used
  • fix various crashes
  • fix UI alignmemt issues
Have the same problem as Gigapixel prior to 5.2.1 fix “Unable to Verify Ownership” dialog will now open the login screen instead of closing the application" It will close the app instantly
Thanks @viwih14385 for posting! we’ve fixed this now in v1.3.6 of Mask
