Download: Windows | Mac.
Full Installer Downloads: Windows | Mac
v1.3.0 - Released August 20, 2020
Major features
- Translucent Mode - Special AI for fabrics and semi-transparent (non-reflective) materials
- Trimap Toolbar - improved discovery and switching to trimap brushes and tools
- Intro Tutorial - simple introduction to the trimap
Improvements
- Close button on tutorials
- Increased range for the Color Range tool
- New Help -> “Re-Install Photoshop Plugins” to install photoshop plugins after mask itself has been installed
- Improved tooltip hints
- Revamped in-app icons
- Adding link to Topaz Facebook group https://www.facebook.com/groups/topazstudioofficial/
Fixes
- Fix a crash on Windows when using some GPUs
- Fix shortcut keys on keyboard which require a modifier be pressed (e.g. German keyboards)
- Fix issue where zooming from multiple views would cause the zoomed image to “jump” in location
v1.3.1 - Released August 26, 2020
Features
- Enabling faster GPU mode on Windows
- New UX flows for product ownership
Fixes
- MacOS 10.13 crashes
v1.3.2 - Released September 2, 2020
Features
- Enable showing trimap brush strokes on all view panes
- Persist edge refinement sliders (can disable in Preferences)
- Improved algorithm for hardness slider
Fixes
- Fix issue with foreground recovery and a blur strength of zero
- Fix update API schema issue
- Cleaner error message for images with “Apple Wide Color Sharing Profile” color profile
v1.3.3 - Released September 3, 2020
Fixes
- fix crash when loading Mask AI from an external editor like Studio 2
- fix installer requiring internet connection on Windows
