Mask AI issues 11-26-19
Version 1.05, Photoshop CS6, Windows 8.1
In using Mask there are recurring, seemingly random issues related to stability and usage. There are, of course, still issues with Mask producing usable results but I will not address those now.
  1. There are times when the plugin simply fails to launch from within Photoshop. Closing and restarting PS usually fixes this. I have also noticed at least one instance where Mask AI did not appear in the Photoshop filters menu even though it was there previously.
  2. I have encountered a space bar pan fail wherein pressing the space bar did not do anything. This required manually selecting the pan tool and then reselecting the brush.
  3. When Mask runs its “one time benchmark” it chooses to use GPU with optimization YES, which is not a good fit for my machine (GTX 1660 Super SC). This actually slows down rendering (best case) or causes the plugin to crash (worst case).
  4. There are times when Mask fails to create a layer and/or return a mask, even though those boxes are ticked.
That’s all for now.
Please raise a support request at the Topaz Labs main website.
