I have had Mask AI consistently crash when, after computing the mask, I try to create a solid color background. The color picker shows up, then the program crashes.
Please go to the Help-> Graphics info menu press Copy and past the info here.
Application & Version: Topaz Mask AI Version 1.0.2
Graphics Hardware: GeForce GTX 550 Ti/PCIe/SSE2
OpenGL Driver: 3.3.0 NVIDIA 391.35
CPU RAM: 12279 MB
Video RAM: 1024 MB Total, 1024 MB In Use
Preview Limit: 1907 Pixels
You’re a bit low on Video RAM (VRAM) - you only have 1 GB whereas the minimum to run Mask AI (and all the other AI apps and Studio) is 2GB, preferably 4GB to run them smoothly.
