I downloaded and had an error message while Mask AI was installing.
I canceled the install and ran CCleaner to clean out the registry. Than I launched the installer again and this time it installed without any issues. I opened up PainterShop Pro 2019 and was able to use Mask AI from within PSP. The only issue is Mask AI will not bring in the mask into PSP. At this time it looks like you have to save while you are in Mask AI and then import into PSP. I hope this will be fixed soon.
