Mainly use DeNoise
Desappointed with the latest rev., the pics are worse after refining; De Noise and sharpening are both bad.
@serge.dery Can you upload an original image so I can run some tests on my end and see if I can recommend workflow adjustments?
Thanks for your feedback.
When I wrote the memo (a first for me), I set aside the picture. I cannot locate the picture anymore (most probably a TIFF file from Canon R7, converted in tiff because elements 2021 does not open CRaw from R7) From that day I am removing noise and sharpen with Photoshop Elements 2021.
I will probably re-try topaz later this week and if problem will keep the picture.
Sorry, remove my comment from you site.
Serge.
No worries! If you try again and the conflict persists, feel free to reach out and we’ll be happy to help.
