nikon z8 nef, lightroom plugin in extras > process with topaz
Updated this evening.
The processed dng has a gross magenta cast. Setting the white balance to “as shot” partly fixes it, but sets the tint to -109. The dng is also very saturated and overall has a very different feel to the original nef. I just want the noise reduction, how do I control these other things?
@gc11 The magenta cast is a bug we’re working on fixing as a high priority. In the meantime, you can try using the Photo > Edit in > Topaz Photo AI workflow which will preserve color and process a TIF instead of a RAW.
Thanks for your understanding as we get this fixed for you.
Or, if you want to stay in RAW format, turning up the Remove Noise slider slightly eliminates the cast for some users.
