Dear Topaz,
First of all I would like to congratulate for your outstanding AI products.
But I have a problem while computing AI pictures on my MacPro 2019.
I have a little software that indicates me all temperatures (CPU, GPU and so on). And everytime I make video computations on Video AI, the GPU reaches 100 degrees or more.
I first had a basic RX580 graphic card. I then upgraded to two W5700X, hoping that the problem would be solved.
And I still have the same problem. Only one GPU is used and the temperature is still above 100 degrees.
I have a PC where I put my 2nd licence and everything is fine.
I think that this overheating problem is recurrent on the MacPro 2019.
You can contact me for further details on makilatv@gmail.com
Many thanks for your work again !
