Macbook pro M3 problem
Ok I have been using Topaz Video AI for a few months and had no problem. I recently upgraded to the MacBook Pro M3 and have been having a lot of issues. The main issue is anything that I export will only play for about a second. If I put a 5 second clip in and have frame interpolation from 24 to 60 on, the program will go for a while and then just stop and export about 1 second of video. I have lowered memory, changed passes, and done about everything that I can to fix the issue. I have also deleted program and installed previous versions and still did not fix the issue.
Does anyone have any possible fixes for this. It worked find on M2 macbook so I do not understand what the problem with new computer would be.
