I’m a new customer to the Topaz family of applications, and I’m very satisfied with the results!
I’m quite unhappy, however, with the GUI. I’m on an iMac running macOS 10.15.7, and I’m on the latest version of Sharpen AI (2.2.2). A number of things are very annoying, and I hope you’ll be able to fix them.
The software overwrites the original files without asking. That’s something that should never happen, actually.
… and before you ask: The “Save Options” portion in the preferences does not exist anymore. I saw it early on, but then it disappeared and never came back. Just shows the title with no settings to be changed.
“Save As” from the menu does not do anything at all. Expected behavior from my perspective would be to save a currently selected picture unter a specific name.
If I start to process a number of pictures by clicking apply, and then click “select all” at the top while it is processing, I get an identical progress indicator on two pictures (but it’s actually only processing one).
Speaking of “select all”: I cannot select all pictures by clicking “select all”, which would be my expectation. It does not appear to do anything when not processing.
After the processing is done, the application quits automatically. I think that’s probably not the intended behavior.
Also, if I close pictures, or press “Command-W”, the application quits, or alternatively hangs indefinitely (beachball).
I’m a software developer myself, and all of these look like GUI bugs that should be easy to iron out. I also suggest testing the application a little more thoroughly before release; these should not have made it into a final product. I’m also offering myself for testing, if you’re short in testers for Mac.
Best,
Shima
