Low-res buggy
Compare the uploaded 2 files - before and after.
The Gigapixel Art & CG model was specifically designed to provide users an AI model for just your use-case.
Our Low Res model is trained for modern digital photography, so with AI generated images like this, unexpected behavior can occur.
With that said, I will be sure to raise this to our development team for further investigation.
OK, thanks. The issue is with batch processing set to auto - as it’s not known upfront what mode will be auto-selected for each image.
