How do you install new looks in studio 2
You can create new Looks yourself from a composite of different Filters. When you are ready just click on Save Look on the top RH side and save to “My Looks”:
But what happens if someone sends me a look? Like we used to do with studio 1?
If someone sent you a studio file … then you can open the file which should have an image with various filters applied … then all you need to do is what Don outlined above.
Hope this helps.
