Looking for GigaPixel with Photo AI
i bought topaz photo ai for $199, thinking that it came with topaz gigapixel? but when i go to sign in to topaz gigapixel it says that i can only to do the trial. if i cant get the topaz gigapixel with the topaz photo id then i’d like to cancel that and get the gigapixel, thankj you so much
TPAI, has upscale which is similar to Gigapixel. Try that. Gigapixel is a separate product.
please contact support@topazlabs.com :slight_smile:
Use the ipscale option:
Hi there the Gigapixel feature is called “Upscaling” in Topaz Photo AI
