I’m trying to run Nyx with stabilization and frame interpolation on a 3 hour video. The render should take a bit over 2 days. However, it keeps hitting a “retry-able error” randomly in during the process, and has to start over. Sometimes after a couple of hours, sometimes after a day and a half. But it’s never been able to run long enough to complete. From the log, it seems like the model cache has been corrupted or simply disappeared. I’ve done the usual uninstall/reinstall and it didn’t seem to affect the behavior.
Here are what I think are some relevant log snippets:
2026-09-06 01-23-34.892 Thread: 0x1fa282180 Info FF Process Output: 5398 2026-09-06 01:23:34.890 ffmpeg[47552:1032045] MLModel Error: 0 The model is not found at URL: file:///Applications/Topaz%20Video.app/Contents/MacOS/../Resources/models/coreMLCache//nyx-v3-fgnet-fp16-384x480-2x-13-ane-mlp/ path: /Applications/Topaz Video.app/Contents/MacOS/../Resources/models/coreMLCache//nyx-v3-fgnet-fp16-384x480-2x-13-ane-mlp
2026-09-06 01:23:34.890 ffmpeg[47552:1032045] Deleting model cache directory: /Applications/Topaz Video.app/Contents/MacOS/../Resources/models/coreMLCache//nyx-v3-fgnet-fp16-384x480-2x-13-ane-mlp
2026-09-06 01:23:34.890 ffmpeg[47552:1032045] Unable to delete model cache at /Applications/Topaz Video.app/Contents/MacOS/../Resources/models/coreMLCache//nyx-v3-fgnet-fp16-384x480-2x-13-ane-mlp
2026-09-06 01:23:34.890 ffmpeg[47552:1032045] Output Err: Unable to compute the prediction using ML Program. It can be an invalid input data or broken/unsupported model.
ANE inference operation failed with error message = Error Domain=com.apple.appleneuralengine Code=8 "processRequest:model:qos:qIndex:modelStringID:options:returnValue:error:: ANEProgramProcessRequestDirect() Failed with status=0x12 : statusType=0x9: Program Inference error" UserInfo={NSLocalizedDescription=processRequest:model:qos:qIndex:modelStringID:options:returnValue:error:: ANEProgramProcessRequestDirect() Failed with status=0x12 : statusType=0x9: Program Inference error} @ EvaluateANERequest
2026-09-06 01:23:34 0x3d384f000 CRITICAL: Unable to run model with index 0 it had error:
2026-09-06 01:23:34 0x3d384f000 CRITICAL: Caught exception in tile processing thread and stopped it msg: unable to run model with index 01libc++abi: terminating due to uncaught exception of type std::exception: std::exception
2026-09-06 01-23-35.860 Thread: 0x1fa282180 Info process exited error occurred: 5398 1
2026-09-06 01-23-35.861 Thread: 0x1fa282180 Info process exited: 5398 6 1
2026-09-06 01-23-35.868 Thread: 0x1fa282180 Info Going to delete path: "/Users/rselph/Movies/Encodes/Video AI/453841236.mkv"
2026-09-06 01-23-35.878 Thread: 0x1fa282180 Info Close and delete path "/Users/rselph/Movies/Encodes/Video AI/453841236.mkv"
2026-09-06 01-23-35.889 Thread: 0x1fa282180 Info Going to delete path: "/Users/rselph/Movies/Encodes/Video AI/output_stab_chr2_nyx3.mkv"
2026-09-06 01-23-35.889 Thread: 0x1fa282180 Info Close and delete path "/Users/rselph/Movies/Encodes/Video AI/output_stab_chr2_nyx3.mkv"
2026-09-06 01-23-35.923 Thread: 0x1fa282180 Info ~TProcess(): destroyed
2026-09-07 05:50:42 0x16fb0f000 INFO: Creating model name prap2 instance 0xc3422b200
2026-09-07 05:50:42 0x16fb0f000 INFO: NETS ["fp16-ml.tz"] OUTPUTS ["params"]
2026-09-07 05:
2026-09-07 05-50-42.955 Thread: 0x1fa282180 Info FF Process Output: 5398 50:42 0x16fb0f000 INFO: Locating local model: "/Applications/Topaz Video.app/Contents/MacOS/../Resources/models/nap-v3-fp16-ml.tz" status: 0
2026-09-07 05:50:42 0x16fb0f000 INFO: CACHING MAY NOT WORK"/Applications/Topaz Video.app/Contents/MacOS/../Resources/models/nap-v3-fp16-ml.tz"
2026-09-07 05:50:42 0x16fb0f000 CRITICAL: Cannot open zip file at: /Applications/Topaz Video.app/Contents/MacOS/../Resources/models/nap-v3-fp16-ml.tz
2026-09-07 05:50:42 0x16fb0f000 INFO: COMPUTED FILE NAME fp16-ml.tz nap-v3-fp16-ml.tz3
2026-09-07 05-50-42.956 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05:50:42 0x16fb0f000 INFO: Locating local model: "/Applications/Topaz Video.app/Contents/MacOS/../Resources/models/nap-v3-fp16-ml.tz3" status: 1
2026-09-07 05:50:42 0x16fb0f000 INFO: CACHING MAY NOT WORK"/Applications/Topaz Video.app/Contents/MacOS/../Resources/models/nap-v3-fp16-ml.tz3"
2026-09-07 05-50-42.982 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05:50:42 0x16fb0f000 INFO: Loading filename nap-v3-fp16-ml.tz3 fp16-ml.tz ["params"]
2026-09-07 05:50:42 0x16fb0f000 INFO: Total Devices: 2
2026-09-07 05:50:42 0x16fb0f000 INFO: DEVICE DETAILS: -3 INSTANCES 3
2026-09-07 05:50:42 0x16fb0f000 INFO: device id: -3
2026-09-07 05:50:42 0x16fb0f000 INFO: Loading cache file: /Applications/Topaz Video.app/Contents/MacOS/../Resources/models/coreMLCache//nap-v3-fp16-ml for file: /Applications/Topaz Video.app/Contents/MacOS/../Resources/models/nap-v3-fp16-ml.tz3
2026-09-07 05-50-43.002 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05:50:43 0x16fb0f000 INFO: device id: -3
2026-09-07 05-50-43.015 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05-50-43.031 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05:50:43 0x16fb0f000 INFO: DEVICE DETAILS: -2 INSTANCES 6
2026-09-07 05:50:43 0x16fb0f000 INFO: device id: -2
2026-09-
2026-09-07 05-50-43.032 Thread: 0x1fa282180 Info FF Process Output: 5398 07 05:50:43 0x16fb0f000 INFO: Loading cache file: /Applications/Topaz Video.app/Contents/MacOS/../Resources/models/coreMLCache//nap-v3-fp16-ml for file: /Applications/Topaz Video.app/Contents/MacOS/../Resources/models/nap-v3-fp16-ml.tz3
2026-09-07 05-50-43.051 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05-50-43.063 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05-50-43.074 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05-50-43.083 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05-50-43.091 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05-50-43.100 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05:50:43 0x16fb0f000 INFO: TOTAL INSTANCES: 9
2026-09-07 05:50:43 0x16fb0f000 INFO: Init backend runner 9
2026-09-07 05:50:43 0x16fb0f000 INFO: Preflight frame index 2 4
2026-09-07 05-50-43.180 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05:50:43 0x16fb0f000 INFO: Preflight frame index 3 4
2026-09-07 05-50-43.265 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05-50-43.342 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05:50:43 0x16fb0f000 INFO: Preflight frame index 1 4
2026-09-07 05-50-43.756 Thread: 0x1fa282180 Info FF Process Output: 5398
2026-09-07 05:50:43 0x16fb0f000 INFO: ---StandardTilingStrategy::StandardTilingStrategy W: 480 H: 384 C: 4 R: 4 X: 318 Y: 232
2026-09-07 05:50:43 0x16fb0f000 INFO: ---StandardTilingStrategy::StandardTilingStrategy W: 960 H: 768 C: 4 R: 4 X: 636 Y: 464
2026-09-07 05-50-47.626 Thread: 0x1fa282180 Info FF Process Output: 5398 frame= 1 fps= 0
2026-09-07 05-50-49.634 Thread: 0x1fa282180 Info FF Process Output: 5398 frame= 5 fps= 1.99203
2026-09-07 05-50-51.131 Thread: 0x1fa282180 Info FF Process Output: 5398 Output #0, matroska, to '/Users/rselph/Movies/Encodes/Video AI/453841236.mkv':
Metadata:
title : Metropolis (1927)
encoder : Lavf62.13.100
