Lightroom / Photo AI issues
Hi
just noticed that if i edit a lightroom raw file, before applying any adjustments, Photo AI works perfectly
Although if i apply adjustments (cropping, masks, tuning… etc) then i edit it in Photo AI, the end file will state unsupported or damaged file…
I have the same problem, the last working version for me was 2.0.4
I have the same problem but only when I do a black and white image, color is see no issues. current software on Topaz, lightroom and MAC.
I did try in on topaz denoise and it works fine
