The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
All requested items have been placed in your Dropbox.
I have done some more investigating at my end. I did discover that specifying either my GPU (Intel Iris XE) or Auto results in the block effect. Specifying CPU results in a normal image (no blocking). Am looking into new drivers currently.
