License will not refresh
HI,
my main computer is getting repaired in the shop so I am using a different Mac. is Photo AI locked to the initial machine you purchased it on as I keep getting the refresh your credentials and to relogin which I do but the system does not then activate the software
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
No it isn’t lock to a PC but you need to logout from the original PC to activate again …
You will need to contact support at the main website.
