Less CG aliasing/noise with different output format
TIFF 16-bit produces less aliasing than ProRes 422 HQ when using the Gaia CG V5 model on Beta v3.2.3.0
i9 9900k, NVIDIA 1070 8GB
The video can be a bit unclear if not viewed in fullscreen
Edit: for a second I thought I must have been viewing different frames of the animation, but just re exported from Topaz to double check and it is the same frames.
I’m also getting different color profiles between 8-bit and 16-bit.
The source is Quicktime Uncompressed 8-bit sRGB, but only getting the right colors when output as 16-bit TIFF
Hello,
Could I take a look at the input file you’re working with to run some test exports? We’re currently trying to narrow down the cause of some color shift and aliasing issues with certain export formats.
You can securely submit your file(s) to our Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Submit to Dropbox
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
