When exporting as an image sequence “keep original frame number” has no effect. I select a range starting at frame say 5000 and the output will be numbered starting at 0. At least with starlight mini.
This is particularly problematic since starlight mini systematically drops the first frame from an export and starts on frame 1 instead of 0. So you cannot rename your files from 5000 if that is the starting point you’ve selected, but from 5001.
Anyways, this bug has existed for months now without any update on the matter?
