At the moment, you can include the filters in the suffix but are you saying having the version number and specific setting information would be much more useful?
Yes, I am. And specifically that this information should be put into metadata, not into the file name. Often I look back at a photo and need to know exactly how I processed it in case I’m redoing something or want to process another photo similarly. This is especially true since TPAI is evolving so rapidly–and was also true for Sharpen AI and Denoise AI.
I’d like to UPVOTE the original post, but there doesn’t seem to be anywhere to do this.
One additional thought . . . What if the settings were kept within a ‘sidecar’ text file like an xmp, but specific to Topaz Photo AI, say .TPAI. This file could be saved within Photo AI (or in a folder associated with it) so that when the same file is imported again into TPAI, the sidecar settings are read and applied (automatically, if the user wishes). The text file would include all settings plus any edited or added masks. For example, I often edit the “Subject” mask as it is not always accurate.
