Mac OS 11.6, 32Gb memory, 8 cores, 1TB SSD, AMD Radeon Pro 5500M 8Gb
It’s been a while since I tried using ‘JPG to RAW AI’ - probably before I upgraded from Catalina to Big Sur. Now, the app starts but the window to load images fails to appear. I have force-quit, deleted the app, re-installed, rebooted. Nothing helps.
I see its running from the command-line (ps -ax) or from the “Force Quit Applications” menu. But there is no active window to load images - only a spinning ball then, from the ‘Force Quit’ app- I see “not responding”.
The version is 2.2.1. I also tried changing the display resolution to the lowest value after checking “Open in Low Resolution”. nothing helps.
