Hi all,
I am currently running the trial versions of Jpeg to Raw and DeNoise. Both programs crash randomly during batch processing. It doesn’t matter if I load 10, 100, or 1000 images. It may crash on the first image, or it may get 400 done if I load a large data set. Typically in my testing I’ve been giving it 200 images, and JPEG 2 RAW was averaging about around 100 (usually 60 or so, sometimes as many as 200 if given a larger set). Since the last update ro JPEG to RAW though, I’ve been lucking to get more then 20 images out of it.
DeNoise is slightly more reliable, but not much.
I have a support ticket in, and it has been submitted to the developer. I thought I’d post here to see if anyone had experienced similar issue and any remedies. I’ve toggled it from CPU to GPU, and it doesn’t seem to make much of a difference, and I’ve tried changing the GPU memory options. I’ve even tried changing from using a cheap USB Hard Drive to a high quality hard drive on a sata connection.
Here are my system specs:
Windows 10.0.18362
Processor: Intel Core 2 Quad Q9400 4 cores /8 threads
Memory: 8GB
Hard Disk: Installation Drive SSD, storage drive is a traditional hard drive.
Video Card: Nvidia 1050ti running Game Ready Driver Version 452.06
Any help would be greatly appreciated!
