I have tried to create a number of DNG files from JPEGs, and the application keeps failing to save the file:
I tried uploading the log file, but it wasn’t allowed.
No need to upload the log, just choose the file format from the Processing panel … You have a choice of either DNG or TIF.
It actually told you the file was undefined on the output side of the main panel.
Hi Don,
I tried selecting DNG, TIF and TIFF (not sure what the differences are between the two TIFs) and received exactly the same error. I hadn’t noticed before that when it processed it blanked out the file format.
Thanks
TIF or TIFF is just an extension but the same format. Next option, go to Help-> Graphics info, press copy and paste the info here please.
OK, I can’t explain it, but now it seems to be working…didn’t change a thing.
