IVTC is not working correctly for non linear source
There are sources (many) that were created by joining differentry pulluped 24000/1001 > 30000/1001
For example if you get pulldown scheme for first scene. On second it may fail, because other fields should be dropped.
Now Video AI can’t handle them.
Yes there are no terrible frames like from very different fields in output. But still you can see artifacts of incorrect fields.
armitageova
I’ll upload source for this.
Can you share the input file with us to our Dropbox for testing?
You can securely submit your file(s) to our Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Submit File to Dropbox
Uploaded it. 04.mkv
Also I’v just uploaded Book 1… mkv file. Its quite strange interlaced source. Looks like IVTC is needed and then all bottom (or top) fields should be skipped because of some sort of bad scan or something like this (all models fail to deinterlace it normally).
