It works quite well on my other PC
I am that frustrated user that could not get a result on one PC but, hurray, it works on another.
Here is my comment on how well it works. Formally I used Remini and find that Topaz AI works well enough with the added advantage that it also can add minor improvements to image areas outside the face recognition fences. I hope that the later ability will get better with time.
I am happy because I think I can now do the work I was intending to do.
Thank you.
what are the specs of each system? It might explain quite a bit
or its a bug… seems to be an issue of lag in v2.3.1 but i imagine it will be fixed pretty quickly…chances are it has been already and they are testing it now. v2.3.0 works fine from what i understand. Of course if its only effecting 1 system its more than likely the system
