It returns a semi-transparent layer with corrupted colors. The scaling is correct though.
Hi.
This issue is currently being investigated if you wish to rollback to a previous version here’s, the link
Here’s the link to contact Topaz Support directly
Topazlabs Support
support@topazlabs.com
Hope this helps
same issue, It has become unusable, quickly a fix!
Hi.
I’m not Topaz Support
If you want quick fix then, either rollback to a previous version or contact Topaz Support directly
Links in my previous reply above
Hope this helps
Exactly the same problem for me too. I have reinstalled but to no avail… Put a real dampener on my workflow.
