After elaboration the result has this terrible blank area in background. I applied only Noise reduction and the sharpen in red flower. In the preview I did not see this effect which appear in the eleborate version
Topaz Photo AI [v3.0.3] on Windows via LRC 14. The photo has been exported an RAW format as plug-in
original photo
elaboration via LRC file > Plug in Extra export in SDK with Adobe extension support ON
colors are changed and banding in the backround
elaboration via LRC file > Plug in Extra export in SDK with Adobe extension support OFF
colors are changed (different from previous version above) and banding in the backround
elboration via LRC > Edit in
export as TIFF, no issue
The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
I uploaded on dropbox 2 examples with teh requested in formation. If you need more please let me know
I did not add the result obtained via LRC Photo/Edit in/Topaz AI since it is fine.
I installed the driver P2000 studio version 552.52 and the new Topaz version, but nothing is changed in all images. I did not send them since no difference.
I woudl like to point that if I do teh some thing via Lrc>Photo>Edit in>topaz AI there is no issue.
The suggested values for first photo are
Denoise - Strong / strenght 28-minor deblur 1 - origional details 9
sharpen - strenght 64 - minor denoise 10
