Issue | Black Pixels along Right Edge with Wonder 3
I upscaled images to 1500 pixels on the longest side using all three intensities of Wonder 3: low, medium, and high. All three settings exhibit the same problems in several images I upscale. And yes, the input images are free of black borders before upscaling. I’ve attached an example, but all the outputs have the same problem.
input (no black border)
output (with black border on the right):
That is a bug on some unusual scaling factor (e.g. 1.2x). We will figure it out. Please give a try with some scale factors like 2x first then you can resize it to any kind of resolution.
I use Wonder 3 with 4x and in this case the issue seems to occur when the dimension is not a multiple of 4 pixels.
  • Both width and height are multiples of 4 pixels: No black borders.
  • Width is not a multiple of 4 pixels, Height is a multiple of 4 pixels: Black border on the right.
  • Width is a multiple of 4 pixels, Height is not a multiple of 4 pixels: Black border on the bottom.
  • Both width and height are not multiples of 4 pixels: Black borders on the right and the bottom.
