Is there a way to retrieve settings based on output file name codes?
Hello All,
Stupidly enough, I forgot to save my settings in a custom preset. Most settings I used are “saved” in the output file name, for example: prob4 thm2 chf3. Is there a list that explains these codes so that I can rebuild the preset?
Many thanks in advance and best regards,
Bas
Video AI saves the settings that was used in the video metadata of the rendered file.
With MediaInfo you can see the settings that was used for that file.
in the Documentation below you can find the list of AIs.
Many tanks for the info, it’ll save a lot of time.
