Is there a way to enable denoise while using the gaia model?
Hello, I have recently been using the Iris model and the gaia model. For the Iris model, there is an option to remove noise, but for the gaia model, there is no such option. And when using the gaia model, it seems that more noise occurs. I’m looking for a way to upscale fhd video to 4k and remove noise. Please help if possible.
there should be a new Model coming out this week or so, which is for High Quality video cleanup/denoise. there you have full manual control. you can either use that model before or after gaia.
Gaia tends to ‘bake’ noise into the video (Turns it into solid spots). I would run any denoising before Gaia.
maybe do a second pass enhancement with a denoise option?
I’m so glad! Since the upscaling process usually takes more than 12 hours, I wanted a model that does all the processing at once, so I’ll see it soon.
Ah… So, when using the gaia model, more noise occurs. Thank you for sharing the model characteristics.
When working with gaia models there was no additional denoise option. After applying the gaia model once, there is also a way to apply other models. However, since the work time is long, I do it when I go to bed or go to work, and if I apply the model twice, I have to wait at least a day. :frowning:
