EVERY SINGLE TIME it updates it removes all pinned shortcuts. It is literally the ONLY app that does this from all the other apps I have purchased. It gets installed into the same directory and is named the same. Why on earth do you make users have to keep recreating shortcuts every update?
I would love it if they fixed this too.
My workaround for now is to find where the application is located and make a new shortcut. It works and stays with updates, but I have to delete the new one that gets made with every update.
Almost as obnoxious as following your normal workflow, going to the shortcut to open it and realizing there was an update and your shortcut no longer exists, so you have to pin it to the start menu again then move it to the group you have it in… every update.
