Is it possible to make a separate grain filter without using AI models?
Is it possible to make a separate grain filter without using AI models? When preparing the material, I use additional Avisynt filters, after which I apply grain. Video AI has a good grain generator and I would like to use it separately.
As a temporary solution I use Proteus with minimal settings, but this is not correct.
a good grain filter can be used for all models would be helpful. Sure there exists avisynth scripts and other tools but better is we can do all in one. Some models has grain option, but it’s to simpel implemented.
I would like to have not fixed grain size only, more random grain where the lower and upper value for grain size can be defined and a slider to control the quantitiy distribution towards more larger or smaller grain and one for the overall quantity.
  1. min. grain size:
  2. max grain size:
  3. Silder for grain distribution quantity: more smaller grain<-> more larger grain
  4. Slider for global grain ammount: less<->more
