Is It Possible To Enchance, Not Upscale?
Hi all,
Can TPVAI enhance/clean up a video without increasing resolution? For instance, if I have a 1080p video in bad shape can TPVAI enhance it with no upscale?
Cheers :slight_smile:
Yes you can.
Just toggle the enhancement switch on manually.
I used to do it all the time.
Not to mention set resolution same as original that’s the other key thing.
