Is it better to x1 the fhd video with Artemis and then upscale it to 4k using the proteus manual?
Is it better to x1 the fhd video with Artemis and then upscale it to 4k using the proteus manual??
Or is it better to upscale to 4k using the proteus manual right away?
This will be dependent on the video you are working with. You can try both methods to see which workflow works best for you.
You should be able to go straight to 4K as long as the input video has enough detail to upscale.
In the past I have used Artemis to denoise before Proteus. It might work well at FHD, but for DVDs, I found it messed details up more than other denoise tools.
