I just purchased an RTX 3080 and I was thinking of undervolting it since it saves power and causes less heat and general wear and tear on the GPU. But I have no idea how well VAI would work with an undervolted GPU. So is anyone currently using VAI with an undervolted GPU?
I tested overclocking once. It was faster.
Undervolting would make it go slower. If you don’t mind that, go for it.
