Iris2 is lot´s better than Iris1…there´s just a little thing sometimes happening when a face is blurred.
It´s the case when Iris2 face recognition is getting disabled due too high blur…at this crossing point Iris2 face recognition should better fade slowly out the more blur is there.
Here you see on the left a head that is too much blurred but an ear is nearly clearly visible reconstructed…
The more a face is too blurred the more of the face reconstruction should fade out.
Iris2 does some really unsettling things. Particularly around the eyelid/eye. I’ve been trying to figure out if I can get better results with different settings or if I need to just enable old models and stick with Iris1.
Iris2 is the better choice in comparison to Iris1(There were a lot alien like faces…now in Iris2 it´s “nearly” perfect)…just a little bit better is needed so that it´s not that visible in too blurred conditions.
That has not been my experience at all. Both of them make alien faces regularly. Iris2 tends to be worse for me. Maybe it’s just that they become more noticeable because it’s sharper.
