Iris LQ v2
Hi, I’ve using IrisLQ for perfect reuslt with VHS source.
You tried earlier to make changes, but after me and others complianed You implemented this:
Adds Iris options to select between Medium/Low Quality. Medium will use Iris-v2, Low will use Iris-v1.
But with this:
Iris LQ v2
Improvements in detail, especially, for non-face inputs.
Improves temporal consistency (reduces ‘marching ant’ artifacts).
Reduces ghosting of the previous frame at scene changes (same as Proteus v4).
Reduces color distortion.
Adds TensorRT models for faster inference on certain NVIDIA machines.
the (sorry for the language) shit is back!
Now I’m looking for v4.0.9, where can I find the version?
/JB
You don’t have to revert to 4.0.9 - just enable the use of older models in TVAIs preferences and then select IrisLQ V1 (this is what I do as well as often IrisLQ V1 gives more natural results with my sources than LQ V2).
If you still want to go back to an older version, they’re all here for you to download:
Latest Topaz Video AI/Releases topics - Topaz Community (topazlabs.com)
Ok, thanks a lot:)
| jo.vo Beta Tester
January 30 |
You don’t have to revert to 4.0.9 - just enable the use of older models in TVAIs preferences and the select IrisLQ V1 (this is what I do as well as often IrisLQ V1 gives more natural results with my sources than LQ V2).
