I am upscaling some old action tv series on DVD from the 80’s with lots of martial arts movements.
I tried Proteus but that gives smears on fast motion. After lots of DVD processing, i noticed that IRIS is a lot better in handling this fast motion and gives the color more punch too. The bad thing is that IRIS can destroy eyes that are small in the background in some scenes. Can this be solved?
I use IRIS with sharpen 5 and Recover Detail 2 only. IRIS results just looks much better for these tv series than Proteus; for Proteus i also had to use Fix Compression 30 for jumping pixels in the background of some scenes.
IRIS is perfect except that it could mess up eyes/faces that are not sharp and on distance in the background in the video. Is there a way to prevent this happening or make Proteus get the same results as IRIS? Or a better model that can be used locally without AI side effects?
Using version 1.1.2.
