Is there a way to go back to the interface of 2.6.4 while using the newer version? I just upgraded to 3.3.4 and the interface is horrible compared to 2.6.4. Just wondering.
Thanks
Thanks
There is not, but if you share the specific pain points you are having, I can help you adjust to the new build.
Here is our Quick Start Guide to familiarize yourself with the new UI.
