Installer Issues
I seem to be having issues when I update from for example Video Enhance 1.7.0 to 1.7.1 that the uninstall stubs are left behind for version 1.7.0 and for every version installed there is a stub that can not be removed in the uninstaller except for the current installed version. can the installer of the new version not understand its updating a prior version and remove the old version from the uninstall list and clean that up please?
You may be better off to raise a support request at the main website as developers only step in occasionally on this forum.
Thanks, I’ll have to dig around and see where that is I guess.
Thanks for the tip.
The main website is www.topazlabs.com
