While attempting to update Topaz Labs’ Gigapixel AI to version 8 (current v8.1.0)
I encountered an error message stating:
“Your CPU must support AVX instructions to install this program”
However, my system specifications are as follows:
CPU: Intel Core i7-13700K
Instruction Set Support: AVX
Motherboard: PRO Z790-A WIFI DDR4 (MS-7E07) v1.H0
BIOS: AVX (Auto)
OS: Windows 10 Pro
For anyone having this error message: “Your CPU must support AVX instructions to install this program”
First step is to make sure your computer has AVX instructions.
If you already had Photo AI on your computer and you are just updating version, then this confirms you have AVX instructions, you can follow the steps in the next section.
