Is there a way to display sources as file names only instead of thumbnail? I want to compare file names and its difficult to do that without being able to have a list of sources. Topaz will display 119 sources but I have more than that and when I add any more sources above that number, even though I can still add enhancements to the files and export them - I don’t see them in the source window. I want to replace some of the sources with color corrected similar ones but it seems there is no way to do that easily.
At this time, there is no way to see videos as source file names only.
We generally do not recommend loading in that many files into the app at one time, as that can cause an overload issue and crash the app. In most situations, users are able to work with various amounts of videos depending on their system’s hardware.
It’s a bunch of short clips but I appreciate what you are saying. List view might be a nice feature at some point ..
Thanks for your super fast reply
Jeff
