Anyone expert in color setting know something about the setting of imput color?
Start to make some setting and see difference..on my source find this
color space: bt470bg
color primary: bt470m
color trc: gamma22
Source are dvd 720x480 maybe NTSC. I search and bt470bg are the old bt601
try to set all on smpte170m and color look more natural
Need to change something for more accurated color?
in the setting there are bt709 (pal?) but miss bt601…
The input color override setting does not convert the color space. It is meant to change how the app interprets the color space for input clips with incorrect color space metadata. The actual color space will remain the same, and the metadata may not update when exporting.
I make some test changing value and see what mediainfo tell…so this is for most of the value
color space
rgb - BT.709
bt709 - BT.709
fcc - FCC 73.682
bt470bg - BT.470 System B/G
smpte170m - BT.601
smpte240m - SMPTE 240M
color primary
bt709 - BT.709
bt470m - BT.470 System M
bt470bg - BT.601 PAL
smpte170m - BT.601 NTSC
smpte428 - XYZ
smpte431 - DCI P3
smpte432 - Display P3
jedec_p22 - EBU Tech 3213
color trc
gamma22 - BT.470 System M
gamma28 - BT.470 System B/G
smpte170m - BT.601
iec61966_2_1 - sRGB/sYCC
iec61966_2_4 - xvYCC
