Improve detail and fix compression issue
Has anyone been having a problem with the latest topaz with fixing compression and improving detail. Mine has started adding grainy purples and greens in dark areas of my videos, destroying my colors. before the update, I would have perfect and smooth colors but now it’s completely unusable. in the first pic you can see the results I’m getting vs the smooth and crisp footage I was getting!
What model and settings?
Can you share a sample video clip?
It might be as simple as enabling the old version of the model.
