Hi guys,
I don’t know if it’s normal but when I import a ProRes + alpha file, the outlines turn pink.
As above.
I tried several times, the outline are like this on the preview & the final file.
Has anyone seen this before?
Thanks!
Hi guys,
Thanks!
We do not support the user of Alpha layers at this time, that is very interesting that they are turning pink! Could you share the file with me?
You can securely submit your files(s) to our Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Thanks!
Just sent the file by Dropbox.
Lmk
Hello,
We’re currently running some test exports on this file to see if we can create an output that replaces the alpha channel with a black background. We don’t currently have plans for alpha channel support, but we’d like to create a more consistent output for these files that does not create a purple color-shift on edges of shapes in footage.
