Images not opening in Topaz 3
When I invoke Topaz in Photoshop 2024, it launches and then stalls, i.e., the image doesn’t appear. I tried restarting my Mac and the problem remains.
I’ve also tried dragging an image file directly onto the stand-alone Topaz program and got the same result.
This problem has cropped up today and never before.
I have 2010 MacPro desktop computer using OpenCore to launch Ventura.
Steps to reproduce issue:
  1. Attempt to invoke Topaz 3 in Photoshop
  2. Step 2
  3. Step 3
First, please make sure that you have fully closed Photoshop before proceeding.
Topaz Labs Download Page
