I’m confused by the documentation. Hopefully someone can clarify. When I upload an image, AutoPilot automatically makes adjustment to the image. Your documentation says that “A green dot appears next to Remove Noise and the sliders when using autopilot settings.” So what does this green dot mean? Is it telling men I’m supposed to make further adjustments manually? Or is the green dot just telling me it used AutoPilot and I don’t need to do anything? If autopilot has made changes, it seems like there is nothing more to do except export my image. So to summarize: I upload the image, autopilot does its thing and I don’t need to do anything manually. The last step is to export or save the image. Please clarify so I understand better.
Thanks
